Posted by Athol Carr on July 06, 2010 at 14:17:29 from (219.89.92.105):
In Reply to: Serial # posted by Chris Quinn on July 06, 2010 at 07:00:06:
The 1550 is the maximum "no-load" engine rpm. I am a bit confused about F-12 orchard model, there was an O012 as the orchard tractor but it is not a Farmall, has same engine and transmission case and most of the gears are the same but its maximum "no-load" engine rpm is 2120
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
