Posted by Dave Miller on December 12, 2009 at 12:48:59 from (166.183.228.45):
I am changing from a 6 volt system to a 12 volt system on a Farmall H. The regulator is mounted on the gen. and it has a magneto. The system I bought shows the wiring diagraham for a coil and distributor. I have talked to a few people and have not gotten a straight answer on the correct way to do the wiring. If anyone has some advise and/or the correct way to do the connection, please advise. Thanks for any and all the help.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
