Posted by JakeF on November 28, 2009 at 18:46:12 from (216.215.19.6):
In Reply to: Need Wiring Help posted by Jon Young on November 27, 2009 at 14:50:47:
Take your test light and hook it between the the battery and the cable. Hook the ground cable up. If there is any draw on the system the light will glow. Now start unhooking one thing at a time starting with the alternator, or the voltage regulator/generator. Then the ignition, headlights, ect. With the test light hooked in series on the cable you wont have the amp draw to hurt anything and even if you accidentally short a hot wire out to ground it will just ground out a small load and turn on the light.
When you find the problem the light will go out. It's much easier on a car or newer tractor as all you have to do is pull fuses, but many more. Just remember on a car or newer tractor you have to pull the radio/clock fuse, dome light, hood lights to get rid of all the normal parasitic draws.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
