Posted by jeffalex2 on November 27, 2009 at 17:47:13 from (71.246.94.148):
In Reply to: Need Wiring Help posted by Jon Young on November 27, 2009 at 14:50:47:
One of the most common mistakes made when rewiring a tractor is crossing up polarity and remembering if you're working with pos or neg ground. The spark and ammeter are indications of a direct short. Be careful, under those conditions, you can quickly destroy components or even cause a fire or explosion.
Assuming you have a wiring diagram and a PROPERLY color coded harness, double check everything. I've run into 2 wiring harnesses where the colors matched the diagram, but for the wrong wires. If it looks good as is, then your harness is not coded right. Hopefully you find an error. If the harness is wrong, you can still use it, you just have to recode it yourself. Use the diagram and an ohm meter to determine which wires are which and label them with pieces of masking tape.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
