I should clarify one sentence. "Raise is spring return to neutral". I';ll rewrite it as "Pull back all the way to raise. Release and it will spring back to hold (or neutral).
Posters with unfamiliar equipment questions should attempt to post pictures. We can't be sure your descriptions are accurate. For instance, you may very well have a four way valve (double acting) but failed to mention it. If that is the case, your set-up and operation will be different than what I described.
I like the original IH 3.5" x 8" cylinders. Both ports are at the top. This means you will not have a loose hose near the ground that might get ripped off.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
