for the rear end, 80-90wt gear lube is fine. it holds about 13 gallons, i generally wait till its on sale at the farm store and pick up some. teh 85-140 works good too. for the hydraulics, 30 wt is what was used in the belly pumps. i run hy-tran in the hydraulics on all mine, that way when hooking up to implements, its all the same fluid.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
