Posted by Peculiar Farmer on May 10, 2009 at 12:13:28 from (74.209.15.201):
While pondering whether to just bite the bullet and remove the oil pump my ADHD kicked in and popped out the inspection plug for the clutch only to find half of the seat cushion. Darn Meeces! Armed with that information I decided to try to prime the oil pump first. First attempt still showed no pressure but after shut down thought I heard oil returning to the pan. Second attempt had the same results but was sure about the oil returning. I then cut a piece of elec. fence wire, removed the gauge and gave it a roto-rooter effect,put my thumb over the hole and started her up. It bubbled a few times and then out came a steady stream of oil. Can't remember being so happy to clean up an oil mess before.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
