We used Zerone years ago that was alcohol and back then most water cooled engines had thermostats for 160 degrees. Usually would drain it in the spring. When engine temps went to 180 and then 195 you had to use permanent anti-freeze such as Prestone, Peak or Zerex. Permanent doesn't mean forever it just won't boil away. It needs to be changed periodically since it will lose the rust inhibitor. One gallon of raw antifreeze will make 2 gallons of a 50-50 mix and even at todays prices it isn't that expensive and I would stay with the name brands. Hal
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
