Posted by Bob Kerr on September 25, 2008 at 06:43:35 from (63.134.174.187):
In Reply to: Price on a 1937 F-12 posted by Bill Thompson on September 25, 2008 at 06:03:52:
To make $ scrapping it considering the work of hooking up trailer and loading it and the gas to haul it in, don't sound like it is worth it for scrap. However if you need something small to tug stuff around with they are dandy for that! A set of steel wheels that don't go flat and need replacing would be worth it if you aren't going to use it on the road. Mine will run all day hard use on about 3-4 gallons and will skid good size logs. It also has a cracked block but most of them do so don't let that scare you. If it has been sitting for years, it may just need the tank cleaned out the oil pan cleaned out and the mag points cleaned up to run. If it turns out to be junk, then sell it for parts or part it out.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
