Posted by GordoSD on June 22, 2008 at 12:30:41 from (66.115.200.140):
In Reply to: h carbarator, posted by poorfarmall 1 on June 22, 2008 at 12:11:15:
You need to totally disassemble the carb, soak in carb cleaner solution for 2-3 days. Then blow out with carb cleaner and air. Then install the complete kit (40$).Check float for leaks. Set the float level, reassemble. Email if you are interested in a new carb, will take yours as core.I do one a month to 100% show standards.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
