On a system as complex as the CaseIH online parts books, you've got to expect that it won't be 100% reliable. There will be times when it's not available, and there is nothing you can do about it except wait for them to discover and fix the problem. Screaming HELP on this forum won't do any good because nobody here can help. It's nothing you're doing wrong. You didn't "press the wrong button." You didn't break anything.
Let the fine folks at CaseIH figure out what the problem is. Give them time, and they will have the server back up for you.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
