Brian: There is a device to make a Super A go slower, it's called Hyrda Creeper Drive, quite simple actually. Tractor is equipped with a remote hydraulic control valve. That powers a hydraulic motor, coupled to the pto shaft. The tractor must be equipped with a heavy duty clutch release bearing as you must operate Hydra creeper drive with clutch pedal tied down. The hydraulic motor then powers the tractor through pto and transmission. If one can still get the release bearing from CaseIH the rest could be built from hydraulic components. I do have a bit of info on this if your interested, come back.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
