Brian: As much as I like the sound of you, ( I design and build 3 point hitches for these little tractors) you've got one chore in there that a Super A is not very well suited for, that being transplanting. Super A are just too fast for transplanting. You'd be much better off with utility with dual range transmission. Then you have the bush hogging, SA can do it, but you will like a center line pto. Frankly I don't 8N is your tractor either, you need something like a 424, 434, etc., dual range transmission and live pto.
Then you will also be able to use just a bit larger disk and field cultivator. Take it from a guy that has a SA, 130 and 140. Sometimes I just wish I had a bit more hp, draft controlled 3 point hitch and live pto.
Yes you can exert down presure with a SA, but how much, you don't pull much with rear wheels off the ground. SA just isn't that heavy.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
