Posted by glennster on February 07, 2008 at 08:18:04 from (75.56.54.142):
In Reply to: massey harris pony posted by steveindy on February 07, 2008 at 07:36:22:
i agree with allan, pull er apart. check the main and rod bearings with plasti-gauge, check piston clearance, ring clearance ect. if the motor was fresh and parts installed were oversize, that is what is causing the stiffness when you try to crank it over. pick up an overhaul gasket set, tear er all down and put her back together, check everything!!!!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
