I have that M that lost a screw in the throttle plate and it still has the brass screen above the carb. When this happened (In the 60s) it made a very loud hammering sound. We pulled the head to find the problem and found the brass screw on top of a piston. I haven't had the head off so I do not know what type of pistons it has. Had a similar thing happen with my 6-cyclinder Ford pickup. I broke off a spark plug and part of the plug tip got stuck in the top of the head. I managed to scrape the top of the piston with a screwdriver and cleaned it off. The pieces went out the exhaust.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
