As Nebraska says--don't worry about a small leak. The neighbor down the road always said"If it doesn't leak more than 5 gallons a day, it doesn't need fixed". The brake lining being oil soaked---- if it is fairly thick yet, try heating the lining material carefully with a propane torch & see if most of the oil will run off. I've been successful using this fix on lots of brake linings/discs.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
