I'd venture a guess that somewhere in the neighborhood of 90% of the H's and M's still in existence have the very leaks you are fretting over. It appears you bought this tractor to use and if thats the case, unless you have a puddle under it everytime you move it, you are commiting mental energy where it isnt really needed. The brake pinion is fix in a couple hours even if you arent mechanical and you have already suggested you arent as worried about the onther leak as you were originally. As referenced before, even with a 7K Super H, there is a fair chance this may occur. After milloins of revolutions, being subjected to dirt, grease and weather, things simply dont fit as tight as they once did. You are asking more of this 60 year old tractor than any die hard Harley guy would ask of a 30 year old machine. Keep the faith. If the tractor does the work you intended for it to do with some reliability, it has accomplished what it was intended for.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
