Re: HELP !! 300 UTILITY
Posted by D Slater on February 17, 2007 at 18:56:36 from (205.188.116.133):
In Reply to: HELP !! 300 UTILITY posted by tom nj on February 17, 2007 at 15:52:02:
First off the tractor serial # would be a 300 because 350 didn't go that high. I belive your engine is not original because even though you have a late 300 U and if some could have had the C 175 put in them, your engine serial # is to high. There's a lot of 350 with a lower engine serial #. Bad news on the PTO,if your tractor has a transmission driven PTO and no T/A. That type has no oil flow to the center housing and you have to remove it and then add seals and all parts needed in it for IPTO. Your pressure plate may have the splined hub rivited on to turn IPTO shaft, if not that would need added. The pressure plate for IPTO will work for both non live and live. Next if the counter shaft in your trans. is one piece its has to change to hollow shaft.Don't remember on 300, but some tractors used spline on end of counter shaft that could be removed and shaft used for both type PTO. The shifting sleeve and PTO shaft from a non live 300 tractor is the same as most H tractors used and as you found different than live.
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
