Re: Generator Pegs Ammeter!!
Posted by Bob M on January 05, 2007 at 11:33:53 from (151.190.254.108):
In Reply to: Re: Generator Pegs Ammeter!! posted by chadd on January 05, 2007 at 11:13:19:
Yeah - either the regulator is poorly grounded or else it is shot. Try this in order: 1 - Run a temporary ground wire from the grounded battery post to the regulator base (not to the regulator mounting base but to the metal relay frame.) Now run the tractor and see if it charges. If it does, arrange some sort of permanent ground connection to the regulator relay frame. 2 - If the above doesn't help, with the engine running at speed first ground the regulator "FLD" terminal. Then jumper the "BAT" and "ARM" terminals at the regulator (this connection may carry 15 amps or more - expect a bit of a spark!). If jumpering causes the generator to charge it's time for a new regulator. If it does not, the problem's with the generator.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
