Re: No low end torque
Posted by ChadS on December 17, 2006 at 11:14:13 from (66.228.96.171):
In Reply to: Re: No low end torque posted by North Dakota H Puller on December 16, 2006 at 17:03:03:
Do you knowwhat the lobe separation angle is on that camshaft?? What you have is the typical low compression engine,,, More compression will surely wake it up torquewise. You need to be in the area of 150-175 psi at cranking speed. Its gonna be hard to do with flat top pistons. Id look for a set of high domed pistons, that will help alot, if the engine has been recently rebuilt,, you can drop the pistons in the sleeves it has already,, just hone them out once more, unless they are really super worn,,, then replace them. Id also bet, it may have cast iron pistons,,,,, very heavy in weight,, with low compression, it will die off quicker when the load is heavy. If it was higher compression, it would help make some extra torque with the heavyweight pistons,,, but still,, no subsitute for aluminum pistons. Id think about pulling apart and upgrading the piston/sleeve kit,, fairly inexpencive to do,,,, One thing I have done in the past was to put the thick H sleeves in another block, and sent it to be bored,, and remove them and put them back in the engine you have,, that eliminates having to remove the engine from the frame and be done inframe,, which saves time,,,, Did that to a Super H and went up to the 350 pistons,,,, the H wont go that big,,, and still have sleeves,,,, Ive seen 300 pistons in sleeveless H blocks with a little honing of the block,,,,, Chad
Home
| Forums
Today's Featured Article -
History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
