Posted by John T on April 07, 2009 at 04:57:07 from (66.244.97.31):
In Reply to: 12 Volt Generator posted by 1 Dollar on April 06, 2009 at 20:38:40:
You ask:
Would a 12 Volt generator off the 1960's-70's Cub Cadet lawn tractors fit an M? Do they have enough amperage?
I dont have any part numbers or specs or data but my best guess is even if it works otherwise (which it likely can) its a low amperage unit as compared to say a 20 amp genny that a car or tractor would require. I doubt it has enough amperage to work as well as a standard 12 volt tractor genny which is more like in the 10 to 20 amp or more range....
Would a (gasp) John Deere 12 volt generator from the 20-30 series 2-cylinders be a better option fit and functionality wise?
Again, no part numbers or specs or data BUT I SAY THAT WOULD BE A FAR BETTER N CLOSER MATCH THEN THE LAWN TRACTOR UNIT
Just pushing around the idea of doing a 12-Volt conversion using a generator.
I would EITHER: Have a shop convert the 6 volt genny up to a 12 volt ORRRRRRRR get another good 12 volt genny OR you could go the alternator route. If you get a good Deere or other (many of any tractor brands still used Delco gennys) 12 volt I dont see much problem with that. Get a good 12 volt Voltage Regulator and wire it correct and polarize the genny n youre off to the races. Dont forget the ignition upgrade requirements and if you change polarity theres some simple to fix ammeter and coil wiring issues
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
