Re: Rebuilt A starts and dies immediately
Posted by lee on June 04, 2005 at 07:34:49 from (68.225.113.254):
In Reply to: Rebuilt A starts and dies immediately posted by Georgia Boy on June 04, 2005 at 06:57:19:
Is it a mag or coil ignition? Either way there should be some advance built into the timing spec. Maybe 8 deg or so. You'll need to find the specs. The ignition may be dropping out after it fires. An easy check is with a timing light. Put a makeshift pointer at the front damper and mark the front damper pulley for TDC and maybe 10 BTDC. I suggest this because the timing marks under the tractor at the flywheel are a pain. Hookup a timing light and fire it. You can do this simple test without the pointer if you like, lots of guys don't like the idea of adding a pointer. If the light stops flashing when the engine stops firing you have an ignition problem. If you go to the trouble of adding a pointer you can use it to time the tractor. If you have a mag I think there is some retard built in on start up with the impulse coupling. Maybe you are too far advanced if static timed to fire at TDC. Maybe you just don't have fuel in the carb or the carb jets are plugged and you just think you've cleaned it.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
