Re: Magneto's
Posted by Bob M on September 28, 2004 at 16:32:54 from (66.67.13.141):
In Reply to: Magneto's posted by Steve M on September 28, 2004 at 15:45:52:
This is "quick 'n dirty" test that works for me: 1 - Pull the center wire out of the mag distributor cap. Plug it onto a good spark plug. 2 - Lay the mag on it's side on a bench. Then lay the plug top of the mag so the plug shell is touching the metal mag housing. 3 - With your fingers quickly spin the mag drive coupling clockwise 1/2 turn at a time (you gotta spin it fast so the impulse doesn't catch). If the mag is good you will get a blue spark with every half turn of the coupling. (You will feel a "bump" in turning resistance at the point where the mag "fires".) This will verify the high voltage section of the mag. To test the distributor part: 4 - Put the center wire back into the distributor cap. 5 - Take a second plug wire and stick into any of the remaining cap towers, then place the other end on the spark plug like before. 6 - Repeat the spin test above. You should get a spark once every TWO revolutions of the drive coupling. A word of warning: Do this only with dry hands! If you are at all sweaty, the mag is good and finger is in the wrong spot you run a good chance of being knocked on your a$$ when the mag fires...trust me!
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
