Re: Farmall 460 gives me a HOT FOOT
Posted by Aces on November 19, 2003 at 17:02:03 from (67.0.20.251):
In Reply to: Farmall 460 gives me a HOT FOOT posted by IronHorse on November 19, 2003 at 15:56:52:
Ironhorse you are asking one I sure never heard of, but let me ask this could it be that when you use the PTO you have the fast hitch in just a little different spot or using the hydraulic a little different. This is what I am getting at, the 460-560 hydraulics did just what you are saying for getting hot, hot enough to burn feet through shoes in cold weather. This is the deal if the fast hitch valve does not return to center it will cause high pressure on the hydraulics and you hot heat buld up. The other thing is the 460-560 had an unload valve to unload the hydraulics because it is an open center system so you need either a unload valve or a load valve as the newer tractors have. The unload valve will most likly fail in the loaded state the load valve more likly fail in the unloaded state. Tjis valve is infront of your feet with that tin around the valves. It will have 4 3/8 cap screws in a plate about 2 x 3" and the relief valve is in there to. There is a piston and ball seat in there if the o ring is bad or the seat or piston it could cause this be carful taken the plate off because of the relief valve spring, I take 2 screws out and put 2 longer ones in or it could pull the last threads out and be like a gun. If you have fast hitch could be linkage or the gears in the hitch valve. Hope I have help some.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
