Re: B Farmall engine trouble
Posted by chadd on April 30, 2007 at 14:26:56 from (155.92.32.116):
In Reply to: B Farmall engine trouble posted by Tracy Gruetzmacher on April 30, 2007 at 11:00:25:
Is the screen still in place at the end of the fuel line where it enters the carb? If so that could be plugged up. That fuel filter must be able to be used for engines without a fuel pump (your B has gravity feed, which isn't strong enough to suck through the thick filter media). We put a clear plastic filter on our M. It ran really terrible and got worse with running time and load, the oil pressure dropped to 25 psi while idling with new 30W oil, and the temp gauge never moved past run while pulling the disk. When I saw steam out of the cap, I had an idea what was happening (it was VERY lean). Took off the filter and replaced the fuel line and the screens (also reset the timing, as it was a little off). Runs like a top, oil pressure is 55 or so at low idle, and thanks to a new temp gauge, it runs just under the run range unless worked hard. Also, I always clean the hole between the tank and the sediment bowl by blowing compressed air into the sediment bowl opening with the line removed and with the gas tank cap off. After draining the fuel system, it is normal (in my experience, anyway) for it to not refill immediately. Only the tractor with a small float bowl leak will refill immediately. Once it starts and runs a couple minutes, the sediment bowl or filter should be full.
Home
| Forums
Today's Featured Article -
History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
