Ford 330=391 parts
Anonymous-0
Some of You guys may have btdt, and therefore can help me . will the intake manifold from a 330 bolt rite on to a 391 as a perfect match ? ,. thanx guys
330 & 361 use's a C4TZ9424G
391 use's a C4TZ9424H intake
they all use the C7TZ9433B intake gasket set.
The intake Holes are bigger on a 391 but it
might run for ya
391 /4 barrell 4 barrel carb has gas leaking issues ,,and a broken water thermostat bolt / the 330 block throwd rod ,, has a rebuilt sweet 2 barrell carb / if parts interchange , should work fine ..
It sounds like the difference is that the 330 is a two barrel manifold and the 391 is a 4 barrel manifold. It might work.Just look and see whether it looks like it will fit without any gaskets to start with.Also look at the size of the ports.If the ports line up and the gaskets work,it will probably work.It will just be a 2 barrel carburetor instead of a 4 barrel carburetor.You could have it either way on the cars.You could switch a car two barrel manifold for a car 4 barrel manifold.I don't know if you could switch a truck manifold to a car engine,but since that's a truck engine it should work.
