Anonymous-0
I just pick up the welder and it will start if I spray cleaner in the carb. It did not come with a tank or regulator. I try to hook up the tank from the grill using the grill regulator/hose.
Setup: Tank -> grill regulator -> 12v valve/switch -> some canister -> regular fuel line -> another regulator (I think) -> carb
When I put 12v to the 12v valve I do not get gas? Should I?
Or should the 12v valve have full tank pressure with NO regulated pressure?
Thanks for any advice.
