teachingscience
Hi all, making progress on the old MF 135. I'm ready to wire it up but have never wired a generator before. the regulator doesn't have the terminals I expected. Its a delco and from left to right it has three terminals: L , bat, F and one on the bottom with no markings. Which one goes to the armature? I was assuming the bottom went to a ground because it is mounted with a rubber isolator on the base so there is no way to ground otherwise. Or does it even need grounding????
Thanks for your help and God Bless
Charlie
Charlie
