There are used deals out there. And there are the tractors that are starting to give trouble and are traded before the large $$$ repair bill.
Figure the used price allowing for one major $$$ surprise bill.
Often enough that puts the price of used within the range of a new tractor with factory sales incentives.
Are you a flat lander on irrigated sand/loam? Or on clay hills dealing with mud and snow while using a loader?
Need a cab for winter show protection?
This tractor isn't shabby for the price.
5075E Utility Tractor (75 hp)
MANUFACTURER
MODEL John Deere
5075E
Official Test
Nebraska Test Number Factory Observed Results
Engine
Manufacturer John Deere PowerTech 3029
Aspiration Turbocharged
Cylinders/Displacement, cu. in. (liters) 3/179 (2.9)
Cylinder Liners Wet Sleeved
Fuel Tank Cap., US Gal. (L) (Open; Cab) ---
Standard 18.0 (68.0)
Optional ---
Underhood muffler Yes
Performance
Advertised PTO HP (kW) @ Rated RPM 61 (44.9) @ 2400 per SAE
Official PTO HP (kW) @ Rated RPM ---
@ Standard PTO @ Eng RPM ---
Maximum @ Eng RPM ---
Advertised Engine HP (kW) @ Rated Speed 75 (55.0) @ 2400 per ISO 97/68/EC
Max Unballast Drwbr HP (kW) @ Eng RPM ---
Maximum Torque (PTO) @ RPM, lb-ft (Nm) ---
Max Torque Rise (80% Rtd Spd) @ Eng RPM ---
Maximum Torque Rise % (PTO) @ Eng RPM ---
Fuel Use, U.S. gal./hr. & HP hr./gal. at:
PTO @ Rated Eng RPM ---
Standard PTO Speed @ Eng Speed ---
Maximum PTO Power @ Eng RPM ---
Maximum Engine Power @ Eng RPM ---
Max Unballasted Drawbar Power @ Eng RPM ---
75% Load, Full Engine RPM (Unballasted) ---
75% Load @ Reduced RPM (Unballasted) ---
Transmission
Std. Transmission; Forward/Reverse 9F/3R
Opt. Transmission; Forward/Reverse 9F/3R SyncShuttle
Reverser No
On-the-Go Shifting (Yes/No/Partial) Partial
Clutch; Wet/Dry Dry
Creeper ---
Power Take-Off (PTO)
Standard Independent 540
Optional ---
PTO Speeds @ Engine RPM 540 @ 2400
PTO Actuation Mechanical (lever)
Hydraulics
Type Open Center
Pump Rated Output, GPM (L/min.) ---
Standard 18.2 (68.9)
Optional ---
Rated Flow @ One SCV, GPM (L/min.) 11.4 (43.1)
Max Output @ SCV Couplers, GPM (L/min.) ---
Maximum Operating Pressure, PSI (kPa) ---
Maximum Hydraulic Power, HP (kW) ---
Hitch Draft Control Load Sense Type Mechanical
Remote Control Valves Available 1 (2 opt.)
Hitch Category (SAE Designation) 2 ; convertible to 1
Hitch Lift Cap. lb. (kg) @24"Bhnd Lift Pt. ---
OECD ---
Standard ---
Optional ---
Hitch Lift Cap. lb. (kg) @24"Bhnd Lift Pt. (SAE) ---
Standard 3192 (1447)
Optional ---
Hitch Lift Cap. lb. (kg) @24"Bhnd Lift Pt. (ASAE) ---
Standard ---
Optional ---
Sensing Type Top Link
Joystick SCV Control Optional
Final Drive
Type Planetary
Differential Controls Mechanical (Pedal)
Availability ---
Front No
Front & Rear No
Engage On-the-Go Rear Differential Lock Yes
Axle Type Flanged
Brakes, Type and Control Hydraulic Wet Disc
Operator Station
Rollover Protective Structure, OOS ---
Rigid - Foldable - Telescopic Foldable, 2-Post
Platform - Flat/Straddle Straddle
Gearshift Location - Console/Floor Floor
Cab ---
Doors ---
Platform - Flat/Straddle ---
dB(A) Rating ---
Seat Suspension System ---
2WD Dimensions
Wheelbase, in. (mm) 80.7 (2,050)
Front Tread Range, in. (mm) 56.9 - 81.9 (1,447 - 2,082)
Rear Tread Range, in. (mm) 55.8 - 71.7 (1,417 - 1,821)
Minimum Rear Tread Setting, in. (mm) 55.8 (1,417)
Front Axle Clearance, in. (mm) 18.0 (457)
Turning Radius w/Brakes, ft. (m) 10.6 (3.18)
Turning Radius w/o Brakes, ft. (m) 11.6 (3.50)
Unballasted Operating Weight, lb. (kg) ---
Approx. Ship Wgt, lb. (kg) Open; Cab 4,634 (2,102); ---
MFWD Dimensions
Front Tread Range, in. (mm) ---
Front Axle Clearance, in. (mm) ---
Turning Radius w/Brakes, ft. (m) 11.6 (2.94)
Turning Radius w/o Brakes, ft. (m) 14.3 (3.63)
Limited Slip Differential ---
Approx. Ship Wgt, lb. (kg) Open; Cab 5070 (2300)
4WD Dimensions
Wheelbase, in. (mm) ---
Wheel Tread, Min. to Max. in. (mm) ---
Turning Radius w/o Brakes, ft. (m) ---
Nebraska Test Unballasted w/Duals, lb.(kg) ---
Unballasted Weight, lb. (kg) ---
Standard Tires
2WD ---
Front 7.5 - 16
Rear 16.8 - 28
MFWD ---
Front 9.5 - 24
Rear 16.9 - 28
4WD ---
Track Widths ---
Country of Manufacture Pune, India
Ballasting Restrictions, lb. (kg) ---
*Notes Updated: 06/08/2009
