Scott Hansen
New User
I have a 59 dexta that I am trying to fix. I fixed all fuel leaks and am adjusting the timing now but the throttle lever won't work right. If you put lever up to low idle it just falls down to high idle. Is there a spring or something that makes it work? Also on the intake manifold there are two copper vaccum lines one off the side goes to the injection pump diaphram but where does the other line go to? Right now one end is on the intake manifold and the other end is laying by the sediment bowl with a threaded connector on it but I cannot find what it connects to. Help Please! If anyone has some pictures of this can you please send.
