teddy52food
Has anyone put points in a WD allis (NAPA) (Echlin) #CS763P? This is in a Delco dist. There is a brass strap but no spring to close the points. But there are 2 horseshoe shaped flat springs in the box that don't seem to fit & work no matter how I try to put them in. I called NAPA & he had no answer either.
Do they match the old set of points that you took out?
There are point sets for CC and CCW distributors.
(clockwise and counterclockwise rotation)
Here's the Standard "Blue Streak" and Borg Warner point sets to fit your application.
If the points the NAPA guy sold you don't look like this he either sold you the wrong part # or someone has been swapping stuff between boxes.
(I don't know if the NAPA part # is correct or not as I don't have my NAPA Farm and Industrial ignition catalog at hand at the moment.)
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/ReplacementDelcoPoints.jpg">
They fit the same but they don't have the spring attached. That is a separate piece & It doesn't fit together.
