massey fergerson 3 point hook up
Anonymous-0
got a massey furgerson 1180 new to me nice desel problem hooking three point to impliment Rino blade and shredder have to push apull pry and what have you to get the pins to line up with holes there ought to be a easier way son has JD3020 its easy what am i missing also does any one know how to oil a sliding door on morton building without taking doors off sure feel dumb and know you all are not thanks for the help
Don't know about a Morton Building but I spray my overhead door rollers with WD-40 periodically. This cleans (washes) the accumulated dust/dirt from the axles and makes the doors easier to operate. Every now and again I have to replace a set of rollers as the wheels break off from the axle.
Hook up the left arm first then adjust the leveling screw on the right one for height,pull the release pin and extend the arm fore and aft, then the top link.
For ease of hookup with a 3pth invest in a quick-coupler adapter and forget about those slide arms. They will stick again. That is a never ending problem. As for oiling a sliding door take an oil can and oil the rail ahead each trolly hanger and slide back and forth a few times. Works good on National track. Not sure how good it would work on cannonball tractbut cannonball track is self-cleaning. Armand
