Loren in MN
I have a Schebler carb that says model TT on the side of the lower casting in raised letters. It also says TT-29-A in stamped letters on the bolt flange for the incoming air side of the carb. It also has the letters T28 in raised letters on the upper half of the carb castings.
I had posted an inquiry in the Minn-Moline forum a week or so back, as this was taken off of a UTIL -Moline U Industrial.
I would like to know what other tractors (Brands/Models) may also have used this carb and if it is in fact a Schebler TT or TTX carb. I seemed to get a few different opions on my first post. Since then, I did more cleaning and found the TT-29-A stamping.
The top or mounting flange measures 3 5/8" at tips of the flange with a 2 5/8" bolt spread. The intake from the air cleaner has a 4 1/4" flange and a 3 1/4" bolt pattern. It does have a different body style than a TSX or TRX carb.
Thank you for any help.
