What do heated cab cost for tractors?
Gun guru
I was out for an hour or so plowing snow in the 0F weather and I am frozen.
What would a heated cab cost for a Deere 2305 tractor, it is a new machine. Are they avaliable for the 2305?
When I was working at Deere, I put one on a 2305. The price will pry drop you to the ground, like anything Deere makes or sells. But, it will sure beat freezing your butt off. Call the dealer you bought it from and have them price it out.
Here's the big question:
Why not just buy a plow truck which will do a better job and have nice heat too!
I have plowed with a tractor and they just don't push snow like a 4x4 truck. Beater 4x4 would be cheaper too. I have a Dodge plow truck front and back blades, heat and a radio/cd player!
Forget freezing on a tractor!
The property management group at work have a 2305 with a loader, mower and pto snowblower.
I would never consider pushing snow when one can blow the stuff away.
I can't recall the name of the heated rops/cab off hand but it's a common aftermarket name.
Yeah, I know but the cost of a heated cab is more than a beater plow truck. If you have a 4x4 tractor with a cab and a plow that can turn, then sure thing. A blade on the back of a tractor is hard to beat but I see guys with a little push blade on the front of a rear wheel drive tractor and that is just hard on the driver!! Too Cold!!
Stay warm!! Global Warming! :)
