Massey Ferguson Diesel Starting Aid
I have a 1960's Massey Ferguson 205 with the Perkins 3 cylinder diesel engine. This was originally equiped with a manifold heater that injected a small amount of diesel fuel into the intake manifold and then ignited it using the tractor battery. I am told this system worked great, but mine has gone kaput. Does anyone know if this part is still available?
Yes the kaut part(the glow plug)an be found on this site i am sure.Check for fire in the wire from the key switch when turned to the left and check for diesel to be flowing freely.This should be a simpel mfix.Mine was.
http://www.phillipsandtemro.com/UserFiles/File/ZEROSTART_Catalog_WEB.pdf
Get a block heater too while at it. Keep the manifold heater for emergency use only.
