Anonymous-0
Well, a little elbow grease to get the tire off and rim repaired, saved a few bucks and learned a few things, so far so good.
When using the cheap ballast fill type adapter to fill a tire with ballast, you need to take out the valve core correct ? Tube has the ag air/liquid type valve, does that ag valve/core use the same tool to remove and replace or what am I missing, have to head over to Napa to get the valve fishing tool anyway. Thanks again !
