Rookie question... I cracked the return line to the filter and when I cranked motor it was pumping fuel through the pump into the return to filter. Is this a good sign that it will work even though Did not get anything to injector lines when I tried (but did not crank for long) OR are these two functions independent (pumping to return vs pump to injectors. )
Do I need to crack ALL the injector lines to see if it pumps or is just one ok?
Thanks again as I try to revive this Perkins
