Hello Stone welcome to YT! I see you edited your post,
often that means a new poster has attempted to post a
photo but did not have any success. Here is a copy
and paste that should help with posting photos, if you
were able to edit that tells me you are in Modern View
which comes up in this discussion. At the end of 2022
the forum host here changed the requirements to new
posters to be able to post photos from a post count of
5 posts to 1 post. I believe this change was only made
on ..Modern View.. so you need to post from there. If
you see ..Modern View.. in a gray bar just above the
message text click on that it will take you to Modern
View. In Modern View you will see the Classic View
option in a red outlined box at the top, just adding this
as a way to verify you are in ..Modern View.. Try to post
your picture in Modern. It should go through if you
have at least posted once if everything I understood
about the change is correct. This restriction was a way
to keep internet bad guys from dropping in and posting
bad pictures with hidden viruses. Pictures post
through the ..Choose files.. button or some such name
just below where it says ..Upload Photos/Videos.. down
lower in the ..New post and reply windows, see photo.
They cannot be pasted into the text area as a file. Also
if you are tech savvy and have a smart phone you can
log in to this sight on it and when you click ..Choose
files.. there should be an option to take a photo with
your phone to post.
An alternative is to go to Tractordata .com in the link
and match your tractor to the photos shown there. The
link is to the Farmall models Jim mentioned, the letter
models follow the number models at the bottom of the
list.
Farmalls on Tractor data
