Geo-TH,In wrote:
I'm wondering if there is a way to use 2 6v batteries. During
starting, put the two batteries in series, 12v only going to the
starter. Then when running the 2 batteries are in parallel and
charger off the old generator?
Not 100%, I think something like this was done on some tractors
using two 12v batteries. 24 volts to starter only and put both
batteries in parallel for charging.
JMOR: Yes J Deere did, but starter did NOT use chassis as ground. Probably could still be done on your tractor, but more high current relays would likely be involved, or a seriously modified starter.
