Oregon Tractor Jack
I bought a new goose neck trailer a few years ago. I upgraded the tires to G rated as part of the order. The first time I aired them up a little the schrader valves started leaking on two of them. There appeared to be small grains of sand or glass beads stuck in the seals. Every time I check the tire pressures I have at least one schrader valve leaking. I did some research and found that there are such a thing as balancing beads. Has anybody used them or found them in their tires? I hate them and want to get them removed from the tires. The local tire shop I go to has heard of balancing beads, but has never seen any.
OTJ
OTJ
