International Harvester Model 286 ignition kit
You need to make at least 5 posts before you can post images.
What is an "International 286?" I'm pretty familiar with International tractor models and that is one I have never heard of.
276 is a British built tractor. Petrol engine with a Lucas distributor. Curious thing about it is that the CaseNH parts page does not offer a breakdown of the
guts of the distributor and lists no parts for it. I will look and see if other British IH petrol tractors have ignition parts listings.
Should be able to post a picture now that you have 6
posts. It is a forum protocol that keeps internet trolls
from dumping unwanted photos on a platform that
likes to keep a G rating. The photos need to be posted
through the ..Choose files.. button at the bottom of the
New Post and Reply window. As I said I web searched
..IH 276 ignition points.. and a lot of results pop up
with pictures. There may be something to the fact that
it could be a Lucas or a Delco distributor.
When I try to post a pic it says there are words that are not allowed per the forum rules. The pics I have searched don't like the same
I am a little confused about this whole, deal mainly the
fact that the part CNHI diagrams I lead you to claims to
be for a 1989-90 model tractor. I really think that is
incorrect and this is the right machine however it was
built in England between 1966-71. The information I
have says it was only built with a Diesel engine. Clearly
the CNHI disagrees with that if those are the right
parts diagrams for your tractor. All I can say is the
drawing of the breaker points seems to be very nearly
correct. So you need to either find a Case New Holland
/Fiat dealer near you and order them or order them
through Messicks, see link. At the link the part sections will appear above the page that pops up. Choose electrical and then the 2nd subsection 2-19 circuit breaker distributor.. the points are the top item listed.
Best I can do for you. Maybe Timmycornpicker has more details for you.
Another option
(quoted from post at 01:51:43 07/09/22)
(quoted from post at 21:11:50 07/08/22) I am a little confused about this whole, deal mainly the
Another option
it is definitely a British version and not a diesel as it says petrol on the tag.[b:d49032f66e] So I am confused as to all the different comments as to the right answer[/b:d49032f66e].
Welcome to YT.
This post was edited by Carlmac 369 on 07/09/2022 at 03:09 am.
I would take them in to a good parts house and they should be able to match them up with something . The rotor looks like an old Chevy cap and the points look like something from maybe from a Chevy also or an old Chrysler.
Well, research tells me that it came from the factory with a Lucas distributor but it could have had a Delco installed as a service replacement during its life.
So without knowing which distributor is on there, we don't know what the correct parts for you are.
Another option
I called Messicks and spent 30 minutes on the phone with them and they weren't able to find anything.
So the number 3072997R91, meant nothing to
Messicks? In the link I labeled as ..Another option.. I
described where to find the distributor breakdown on
the Messicks site. In that subsection it only has two
items that you can place in your cart to purchase, one
is called ..Breaker.. which I can only assume is the
points. The other is the condenser. I can also only
assume that breaker is some odd British term for them
because they do indeed ..break the circuit.. As I said
before all I can do is suggest these are right because
the parts drawing shows them to be representative of
the ones in your photo. If you go to the actual CNHI
that I linked you get the same diagram and number. I
do agree with the gentleman that says the rotor looks
like it is from 50s or 60s Chevy ..Delco.. 6 cylinder
distributor. Sorry about the confusion trying to help
you the best way I know how.
(quoted from post at 11:24:16 07/09/22)
Another option
A picture of the distributor and cap would be helpful.
Also, there should be a number on an ID plate attached to the distributor or stamped into the distributor body itself.
(quoted from post at 10:55:51 07/09/22)
Another option
(quoted from post at 11:08:51 07/09/22)
Another option
/quote]
I appreciate all the you guys are offering. I am in Maryland trying to get information from my uncle back in Ohio where the tractor is. Sorry if I am not providing better information
