Animals eating my garden
37 chief
I have rabbits, and other animals eating my garden. I put up a fence charger, with two wires, One wire is 1 inch, the other about 3 inches off the ground. I had a visitor last night. I could see the ground tore up where something made a hasty retreat. Any of you use an electric fence to protect you garden? How does it work for you? I normally use chicken wire, but the animals find a way under it. This is the first year for the electric fence. I had a 12 v fence charger, but it quit. I was running it from a battery charger. I guess it didn't like it. I bought a 110 volt one. Stan
My wife calls me Elmer Fudd. Trouble is rabbits are pretty safe when I get out my .22. Can't hit the broad side of a barn anymore. Last time I shot at one I'm sure I heard him laughing. Gonna have to start using the shot gun. I use electric fence around the sweet corn patch to keep the coons out.
This post was edited by ADB-Ia on 06/23/2022 at 07:57 pm.
For the last 25 years I've put an electric fencce up. I take 4 pvc pipe cut into 12 - 14 long strips cut on my table saw. I v shape one end and put a slit on the other. Driven in the ground, it makes a fence about 5 inches off the ground, with T posts on the corners. Raccoons, chickens, and dogs won't cross it. Rabbits seem to sense a safe area and hop over it, even nesting in strawed areas. I await other's comments on how to keep rabbits out.
I got tried of feeding squirrels and chipmunks with our bird feeders, so I electrified them with a small fence charger. It works good on the squirrels, but the chipmunks eventually figure out how to jump across the gap.
Dad uses milk jugs for the bottom wire, and then second about waist high like for cattle to help keep the deer out. Occasionally he finds the fence torn down from them running into it at first then that ends also. He puts it around the garden and his sweet corn with steel posts at the corners. He ties the corners with bale plastic bale string. His tension adjustment that way.
I had a similar problem with rabbits, ground hogs, and other small critters eating my garden. A local farmer turned me on to Premier fence. They sell a net type fence that is electrified. It is about knee high and I power it with a standard fence charger. It keeps the smaller critters out. They sell higher fences for the larger critters.
I solved my problem with rabbits by putting cotton balls soaked in fox urine on small wooden stakes about every 12-15 feet around my garden. It stopped all small critters. Re soak every couple of months. I had a 1acre garden.
My garden is fully fenced in with cattle panels, covered with poultry netting to stop the rabbits, and I still need a single electric fence wire 2 feet above the ground to stop the 'coons from just climbing over. Occasionally something does get tangled up in the electric fence and it gets wrecked, but it still stops them, and I can fix the damage.
I am using a 110 volt Zareba fencer with I think a 10 mile capacity. I inadvertantly made contact with the fence ONE time. WOW. My left arm was sore for a full day after that.
I use an electric fence to keep deer out we don't have rabbits or ground hogs around here so I charge 3 wires at 12 2' and 3' with 2 more dead wires at 4' and 6'.
Yeh those Zebra fencers really pack a wallop!
They will make your gold teeth burn your tongue.LOL
This post was edited by Den N Ms on 06/24/2022 at 07:32 am.
