Hello!
I can't get my tractor to start after changing fuel filers and replacing the mechanical lift pump. I accidentally damaged the threads on the part of the lift pump where the in/outlet are so I recovered that part from the old one, cleaned everything and put it back together.
As I push the lever on the lift pump, it pumps away, but after about 20 squeezes it will gradually loose all compression. Is that a definite sign that the lift pump has a problem? Or is that perhaps how it's operating? I know that depending on the cam's possition in the crankcase sometimes the lever does not get good contact, but I have tried to turn the engine over, and the problem is the same everywhere.
If I wait for a a while, the compression comes back but goes away again after I pump a few times again. I suspect it draws in air? Any experience with this?
