Hyd hose fitting another pic
300jk
Thank you for all the responses yesterday. I believe it is the boss o ring style. This is a better picture of the cylinder. Thanks again !
(quoted from post at 14:29:07 12/11/21) Thank you for all the responses yesterday. I believe it is the boss o ring style. This is a better picture of the cylinder. Thanks again !
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto110450.jpg>
Yes, O-ring Boss. The chart I posted for you yesterday will give you the size if you measure the threads and match those measurements to the ones on the chart.
Measure it, no guessing. An easy check is to use a fine thread capscrew/bolt. From 5/16 (-02) up through 5/8 (-10) sizes the correct size common fine thread bolts will thread right in and give you the size for certain, no guessing. Above that you will need to measure the diameter, those are all 12 pitch threads.
I use an adapter fitting from male o ring to female npt and keep help extra hoses around incase i have one blow in the field.
Years ago I had a friend who could not seem to understand hyd hoses where not a one size fit all. Then one day he told me the F you and I said that is it. Last I heard he has a lot of stuff that no longer runs
