(quoted from post at 21:01:42 12/05/21) You still havent informed the masses of
what material you want to move with this blade. It could
be awesome, or it could suck.
(quoted from post at 10:28:56 12/06/21)
6 feet or 72 inches is way too much . Tractor should be ok however with a 71 inch wide blade.
On a serious note, as others have stated, we need to know more .
(quoted from post at 10:33:54 12/06/21)
Will probably be ok. It the blade three point hitch CAT I or CAT II ? Tractor appears to be a small but robust unit . https://www.tractordata.com/farm-tractors/010/3/1/10319-bobcat-ct2025.html
(quoted from post at 11:09:05 12/07/21) King Kutter is a light duty cheap blade, and your new tractor looks hardly any smaller than the tractor the blade is mounted on.
The tractor will easily destroy that blade and not even break a sweat if you abuse it.
Per the specs, the tractor has a 1631lb lifting capacity. Your blade might weigh 300lbs.
The tractor is also 64" wide per the specs. A 6ft blade at an angle will barely cover the wheel tracks.
Just use it. It will be fine.
