crsutton81
I want to fix a 2 seated carrier with provisions to put baskets on the 3 pt hitch about picking produce with where 2 individuals can ride along to harvest the stuff. I know Farmall made a hydraulic driven creeper gear that attached onto the pto and the clutch was tied down and hydraulic power drove the tractor via through the pto. There was also a mechanical version that was driven off of the fan belt then a chin to the pto. Was there anything made that was comparable to work on a JD 420 ? I have a fair amount of hydraulic motors, valves and such. Is it possible to tie into the current hydraulic system to run such as this ? If so how large of a hydraulic motor would
it take to make it work ? Looking to slow it down into around the .01 mph range without slipping the clutch to get slow enough to do a good job.
