2013 Chevy Silverado 1/2 ton transmission filter
rrman61
I changed my transmission filter on my 5.3 -6 speed automatic yesterday.is their a trick or procedure to get the pan all the way off?the exhaust was in the way of it dropping down and components in the transmission wouldnt let the pan move far enough forward.I did have it sagging enough to replace the filter though
A well placed pry bar is your friend. The exhaust will flex just enough with a pry bar to get the pan out.
What's my trick?
Twice I've had my filter and fluid changed at All Tran.
Change it every 60k because I pull a trailer.
Fluid change is cheaper than a rebuild.
153,000 it had 101,000 on it when I bought it.I believe its recommended to have it serviced every 50,000 miles
