Vinegar Ben
I just installed new battery, regulator, key switch, wiring harness, plugs and wires, coil. distributor cap, points and plugs, hydraulic oil, motor oil, anti freeze, remove gas tank and cleaned [whoever said Henry Ford was a smart man?] Why in the world would you design a gas tank that is anchored to the hood? The hood has no hinges to raise it forward. Guess Harry Ferguson was the bright one of the 2.] Engine cranks, doesn't even act like it wants to start. I have checked firing order, traced wiring harness-have 6.33 volts to starter, generator, to coil. Have fire at plugs. Polarized generator/regulator. The only thing I haven't checked is gas at the Carbuerator. Any ideas, anyone? Thanks
