Well Its broke I guess Im done for today
Ever had one of those days? I was 4 rounds in to brush cutting, the tractor started to stumble like it wasnt getting fuel, then I heard a pop looked back and saw this. I said a few things I cant repeat here. Ive never had a yolk break like that before. I wonder if the tractor bucking shocked the pto? The shaft is old I guess it could have been weak and finally let go. I dont know but Im quitting for today before I really screw something up.
Most of that is older break, you can see the color difference. My guess is you hit something and broke it some then it just gave up. The cough very well could have been the last straw so to speak.
I agree. There is no evidence of discoloration but I wonder what the original diameter of the hole was supposed to be and the original thickness of the walls on that yoke.
I went back to the scene of the crime and found the other half of the yolk laying right where it broke. It looks like it might have been cracked looking at this half. Might be hard to tell in this picture.
Does the cutter have a slip clutch or a shear pin? If it has a slip clutch you should loosen the bolts and slip it once before starting cutting in the spring, and re-tighten it. Sitting over winter they will stick, especially if left outside.
By my uneducated eye about three fourths of the break is discolored in the first picture. Very little of the break is clean looking. I vote for the previous fatigue idea.
Notice the brinelling on the exposed ends of the cross. They are the groves worn in the cross by the needle bearings. It may have contributed to the failute as the needles can't roll. It is a normal failure mode from wear.
You could check before a failure by trying to turn by hand in tbe direction of normal rotation and moving the free yoke. If you feel any brinelling, replace the cross assembly.
I think your on the money. My dad and I have used this mower for 15 or 20 years now and we have both hit things with it in the past. I think it was fatigued and today was the day it finally broke.
Well now you know what the limit is, Back off the smoke screw half turn and you will be fine. Hard to keep light equipment healthy when your running it behind extreme horsepower like you have there. :>)
(quoted from post at 19:02:46 05/24/21) Notice the brinelling on the exposed ends of the cross. They are the groves worn in the cross by the needle bearings. It may have contributed to the failute as the needles can't roll. It is a normal failure mode from wear.
Not sure what you mean by the word brinelling. How would that feel?
Brinelling is where the needles wear into the cross leaving little grooves all in a line.
You can detect by twinsting the yoke in the direction of the normal drive load and rocking the yoke in two
directions causing the needles to try rolling, and that is what you feel. If you feel anything other than
smooth, replace the cross before it fails.
(quoted from post at 13:33:24 05/24/21)
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto89520.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto89521.jpg>
That is why I own two Bush Hogs.....nice to have a backup when doing custom work.
