Ford Jubilee Oil Pressure Line
Bill 1863
New User
Does anyone know the thread used on the gauge end of the oil pressure line on a Ford Jubilee? I am having a rough time finding an adapter that works for the gauge and the line. I'd rather not replace the line if I don't need to. I have a tap and die set, but that thread is not in the set I have.
Thank!
(quoted from post at 16:59:42 05/14/21) Does anyone know the thread used on the gauge end of the oil pressure line on a Ford Jubilee? I am having a rough time finding an adapter that works for the gauge and the line. I'd rather not replace the line if I don't need to. I have a tap and die set, but that thread is not in the set I have.
Thank!
As it left the factory it would have had a 1/8" steel oil pressure line with an internal (IIRC) special internal compression fitting/nut that screwed into a brass adapter that threaded on to the 1/8" MPT threads on the gauge.
NO way of guessing from here if that's what you still have or if a P.O. has mixed/matched/changed parts.
Can you measure the O.D. of the line and post a photo of the fitting on the line and the back of the gauge?
